Smallest Adapters Available?
  • feef
    • Mar 2014
    • 17
    Im looking to fit a set of wheels design for a Porsche on my E30( 4x100 to 5x130). They are relatively low offset which would require minimal spacing. Ideally I only need to space the wheel about a half inch (13mm+-). The smallest adapters I've been able to find are 18mm thick. Is there anything smaller than this? Sorry if this is an obvious question and thanks in advance for your help.
    -Ethan
  • lambo
    Captain Scene Points
    • 10953
    99% sure 18mm is the thinnest.
      • 37834
      Yup. 18mm.
      Grover Beach, California
      BimmerHeads.com
      • jrockbk
        • Jun 2013
        • 369
        If the wheels have center caps that cover the bolt holes, you can fill and redrill the wheel, but it's very expensive.
        • dannyyisntt
          • 3141
          Really not as expensive as you'd think. You can have them mill the surface after fill and drilling and they'll look a lot better as well.
          • feef
            • Mar 2014
            • 17
            I didn't really want to go the route of having them redrilled but does anyone know a place that does that sort of work in the tri state area? I definitely won't ship the wheels somewhere. Not worth it in my opinion.
            • jrockbk
              • Jun 2013
              • 369
              Perfect Metal Finish in Newark, NJ
              Espos Staten Island, NY
              • ak-
                • 12422
                shave a little off the back of the wheel hub if you can?
                1991 325iS turbo
