56.1 to 57.1 Centerbore wheel spacer
  • theinvictus1
    • Aug 2014
    • 8
    Do they exist? I just picked up some rather ugly (rattle can, several times over) Team dynamics wheels, 16x7 E35 (might fit offset wise,) but they appear to be the Honda/Acura/any other japanese car centerbore (56.1) I know they can be bored out, but I was curious if I chould simply find a hub centric wheel spacer that is tapered so that I can kill 2 birds with one stone, get the tire further away from the strut, and make the wheels fit the hub size?
    Does anyone make them? anyone have a link>
    Thanks.
  • nrubenstein
    • 3148
    It'd be custom, but yes you can do it. To get to a smaller hub size, it'll have to be a big spacer, though.
    I would prefer to get them turned. 16x7 ET35 actually fits pretty well with coilovers.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • theinvictus1
      • Aug 2014
      • 8
      hm i'm guessing "custom" will eat up the savings I got on these ugly wheels. I got the car 2 weeks ago as a track day (buttonwillow) car to help hone my skills for 24 hours of lemons, ( we run an e36 in that ). I'm guessing a machine shop is where I'd go to get them bored out? or a high end tire shop? I could just run a hubless spacer and eliminate the centric part entirely but that'd be quite a thick spacer, and may cause me to snap the lug bolts around one of the more high speed corners which would be bad.
      • MC Hammered
        • Jul 2008
        • 2076
        That the wheels to a wheel repair shop and they can can the centerbore 1.0mm. I had some wheels that were 56.6 cut to 57.1 and the wheels slide on perfectly.
        If you want a hubcentric & wheelcentric spacer then check out www.motorsport-tech.com
        My 1989 e30 s52 Touring... this is Betty
        My 1989 325i vert (sold)...this is Nina
        My 1991 M5 (sold)... this is Veronica
        Photo comparison: OEM vs aftermarket windscreen for a convertible
        • theinvictus1
          • Aug 2014
          • 8
          so I found a shot that will be it for 15 bucks a wheel, provided I unmount the tires first.
          So by eye balling the tires that are on the wheels right now that these are going to clear the shocks front and rear by a cats whisker. the tires are 16x7 however they are only 205 tires, so I'm curious as to how large of spacers to get, if I get a 5mm spacer can I get away with non hubcentric ones since the hub centric section on the wheel hub is 13mm. how big can I go without being hub centric? also, given the 35 offset of these wheels what is the ideal spacer thickness that will let me run the largest tire.
