15x8 with 225/50??
  • fresh_TD
    • Aug 2013
    • 2457
    15x8 with 225/50??
    can I run a 15x8 et15 with 225/50 with out any issues? thanks in advance
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • LJ851
    • 7919
    Lorin
    The M30 is God's engine.
    • Mr. Tasty
      • Jul 2011
      • 3421
      you really didn't even try, did you?
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • fresh_TD
        • Aug 2013
        • 2457
        I did...nothing straight answer though..do you know?
        Sent from my Samsung Note 3
          • 37832
          It will work with a nice roll front and rear. It's going to be pretty damn flush though.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • fresh_TD
            • Aug 2013
            • 2457
            Thanks
            • blasphemy101
              • Apr 2012
              • 170
              Why do you want to run that size over 225/45? From a quick search on Tire Rack, it looks like that size offers greater tire selection and it gives you a little extra clearance.
              [EDIT] Super bump. I'm an idiot lol
              The Great Big M20 Timing Belt DIY
              Some good information I've found online (no affiliation):
              Turbo Tech (Garrett)
              Four-cycle information and cam properties for beginners (ISKY Racing Cams)
              • Regnar75
                • Sep 2011
                • 483
                im using 225/50r15s with ET12, Falken 912s. Bilstein sport struts, eibach sport springs, i rolled both front and back fenders (back probably didnt need it unless your lower) but i also had to modify the front inside tire well, the wheel was rubbing on full lock and during higher speed turns i kept the top guard just the front inner splash guard is cut. i like the meaty look as well.
