Lug Bolt Length With Spacers
  • Bullhead
    • Sep 2014
    • 532
    Hey all I searched lug bolt 5mm spacer and came up empty. Do I need extended lug bolts with a 5mm spacer because it seems that not enough threads are catching for my taste. Are there any other BMW's that carry the same bolt diameter thread size etc... but longer?
    sigpic87 325E The Honey Badger
  • RedReplicant
    • Oct 2009
    • 270
    http://www.pelicanparts.com/bmw/cata...Prc46_pg15.htm
    91 318is - Gone
    16 VW GTI
    07 Aprilia Tuono
      • 37829
      Motorsport Hardware should be able to source anything you need. Contact them!
      Personally I'd go with a stud kit.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Liquidity
        • May 2014
        • 395
        Stud kit for sure. Waste of time and money having a bunch of different length lug bolts for different spacers because don't forget, if the lugs are too long, they hit what's behind it.
        • Bullhead
          • Sep 2014
          • 532
          Right on thx all I am going to look into a lug kit right away.
          • agent
            Vice Grand Pubaa
            • 7960
            Another vote for Motorsport Hardware. When it comes to customer service Ryan is second to none.
            Originally posted by kronus
            • hippiester
              • Feb 2014
              • 64
              Super happy with my stud kit, arrived real quick as well
              • Bullhead
                • Sep 2014
                • 532
                I actually work in a large machine shop. Could I make my own m12 studs if they were grade 8? I can also turn the angle into a lug nut, seems I may be able to save some money there. I would also like to know a good length that you all are running for small spacing or no spacing at all, thanks.
