tire size for a 17x7 in rim... will a 235/40 fit??
    • 37825
    Originally posted by Mystikal
    They're on the fence. Pilot Spot knockoffs, but didn't quite come out as good.
    If you have to back down to 215's, at least get something GOOD. RT-615's would be my choice.
    I'm learning tire life > stickyness. I didn't put many miles on those RS2's and they are already noticably worn.
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • Mystikal
      Wheel Fitment Expert
      • 9602
      Tire life also =/ stickyness.
      It's just physics man. The better performance you have, the less they will last. If you want a tire that will last reasonably long and still kick some ass, look at the new Kumho SPT. Excellent tire, just ordered some for my mom's E46 last week.
        • 37825
        Better than the Hankook I previously mentioned?
        I'm looking to spend $90 per tire or less and prefer to purchase from www.discounttiredirect.com so shoot me your best reccomendation out of tires in that price range in 215/40/17 if you could.
        Santa Clarita, CA
        www.BimmerHeads.com
        • Mystikal
          • 9602
          Yes, SPT's are MUCH better than K104's.
          Looking at DTD for you, the only tire under $90 I'd touch is the SPT. Beyond that, the G-Force at $98 is the next excellent tire.
            • 37825
            Thanks as usual. :)
            Santa Clarita, CA
            www.BimmerHeads.com
            • VAniLLAGOriLLA
              • 5
              Originally Posted by VAniLLAGOriLLA
              So will 215/40-17 fit on 17x7 under my wheel wells with no suspension mods? Or should I go ahead and suffer with these bottlecaps until after my suspension is done?
              It all depends on the offset of the wheels. I wish people would understand this.
              OK so my offset is 38 on a 17x7 rim so i'll have to use a 15mm spacer. then 215/40-17 should fit right? Even after I do suspension I only plan to drop it 1.5 in front and 1.25 rear.
                • 37825
                A 15mm spacer is good but a 10mm spacer would also be fine.
                Santa Clarita, CA
                www.BimmerHeads.com
                • VAniLLAGOriLLA
                  • 5
                  thanks pimpin
                  • emmi
                    • Mar 2006
                    • 84
                    so if u want 215, u'll need wheel spacers? if thats the case, whats the widest i can fit on 17x7s? will 225s work?
                    13 ph15h c1g4123tt35
