Will 17x7 +40 offset fit
  • CollinsE30
    • Nov 2014
    • 27
    The wheels im looking at are Kosei zokus. They are 17x7 square setup, tires are 225/45/17. with my fenders rolled or even with flares will they fit without spacers or will they require spacers, if so, what size spacers. will they clear the brake calipers being +40 offset?
  • e30bulldog
    • Jan 2009
    • 228
    Those tires are way too tall and you will need a 20mm spacer for them to look half way decent. I am running a 17x7.5 up front et41 with a 25mm adapter. Also running 215/40/17
    • CollinsE30
      • Nov 2014
      • 27
      E30bulldog, the tire specs are actually 205/40. im not sure if that will clear stock calipers but do you think they will fit without spacers considering i gave you wrong tire specs before.
        • 37833
        They will not fit without spacers. The rear "might" but it will look ridiculous.
        205/40 works but is undersized. 215/40 would be best. For spacers I'd recommend a minimum of 15mm all around.
        Grover Beach, California
        BimmerHeads.com
