Friend of mine had a 91 Passat, sold it, and his wheels are up for sale. Speedline Corse, 17x7.5
It says et35 on them, so I would assume I'd need 10mm spacers all around to make em fit, right?
My other concern was the centerbore. We put one wheel on my car, and it seemed to fit for the most part (the car was jacked up pretty high on jackstands so the wheel was at a different angle, I'd assume it would rub the strut housing if the car was on the ground, hence the spacer).
the center bore seemed pretty darn close.
I checked vwvortex, and it appears the passat is a 57mm centerbore.
can I do anything to run these wheels?
