Extended lugs
  • Th3importedguy
    • Mar 2014
    • 190
    Extended lugs
    I put 10mm spacers on my car. How long should I buy my lug bolts. 30mm or 40mm
    E30 is life :finger:
  • Tom.
    • Sep 2012
    • 121
    Stock bolts are 26mm.
    source:
    http://realoem.com/bmw/showparts.do?...92&hg=36&fg=15
    http://www.ecstuning.com/Search/36136781150/ES65864/
    • Th3importedguy
      • Mar 2014
      • 190
      Will 40mm work fine?
      • gotaloveRWD
        • Jul 2011
        • 708
        26+10=36 40 sounds like it should work just fine
        IG- nv_e30
          • 37834
          Or just buy a stud kit. Bolts suck! :D
          Grover Beach, California
          BimmerHeads.com
          • DasTaco
            • Sep 2013
            • 43
            • glnr13
              • 1334
              stud kits are better. if you have drum brakes in the rear you have between 6 and 8mm of room between the stock position and the point that a lug bolt will slam into the drum brake adjuster and cause your car to freeze in it's place.
              • Th3importedguy
                • Mar 2014
                • 190
                Okay so I'll buy the stud kit. And I already have spacers but there. It Hubcentric. Does it make a difference of I buy Hubcentric spacers. My wheels aren't hub centric so would I need to out a hub centric ring on top of the hub centric spacer. Sorry lots of questions its a bit confusing
                • glnr13
                  • 1334
                  yes, you should get hubcentric rings for your wheels if they are aftermarket. it's been debated for years, some say you need, some say no. I say yes, anything to help prevent wobbles i'm down for.
                  • Th3importedguy
                    • Mar 2014
                    • 190
                    And put them on top of the spacers?
                    • glnr13
                      • 1334
                      the rings go into the back of the wheel
                      • Th3importedguy
                        • Mar 2014
                        • 190
                        OHHH okay thanks
                        • SkiFree
                          • Jun 2011
                          • 2766
                          Hubcentric spacers only work if you're talking over 10mm thick. Any thinner and it not possible for the spacer to be "hubcentric" (think about the chamfer on the hub itself).
                          ADAMS Autosport
