Originally posted by Sean
borbet wheels
Hubcentric/correct offset:Originally posted by SLEEPERraceralright thanks, i guess il just go with some weaves...at least il know they'll fit. uhhh its difficult to find rims for the e30.
Euro weaves - 15x7 - et24 (16-17lbs?)
BMW Style 10s - 15x7 - et24
Ronals - 15x7.5 - et25 (18lbs)
Borbet Type C - 15x7 - et30 (16.5lbs)
Team Dynamics Pro Race 1/2 - 15x7 - et25 (13.1-2 lbs)
Rota Slipstreams (custom) - 15x8 - et20
Hartge - 15x7 - et25/26
BBS RZ's - 15x7 - et20
Zender Turbo - 15x7 - et20
Zender Challenge - 15x7 - et25
BBS RG003 - 15x7 - et25 (12lbs forged)
ACS ?? - 15x7 - et24
Borbet Type A - 15x7 - et25
Schnell318's 15x7s - et 25
BBS RA - 15x7 - et13/25?
Revolutions - 15x8 - et20 - $$$ (hubcentric or not??)
ASA JS1 - 15x7 - et25Comment
I doubt you will have a problem with hub size.... true honda hubs are smaller than e30 hubs, however most likely these wheels were not made honda specific. meaning the hub size on aftermarket wheels are generally made much larger so they can be fit over many different vehicles hubs.Comment
Originally posted by e30evolutionI doubt you will have a problem with hub size.... true honda hubs are smaller than e30 hubs, however most likely these wheels were not made honda specific. meaning the hub size on aftermarket wheels are generally made much larger so they can be fit over many different vehicles hubs.
so do you think they'll fit my car??Comment
that depends on if these were made with hubcentric rings or not. my Cs were hubcentric by themselves, so ask jweb or bimmer8604 who have run 16x7.5 Type Cs before.Originally posted by e30evolutionI doubt you will have a problem with hub size.... true honda hubs are smaller than e30 hubs, however most likely these wheels were not made honda specific. meaning the hub size on aftermarket wheels are generally made much larger so they can be fit over many different vehicles hubs.Comment
well i gotum and they fit in the rear with a lil forcing onto and with a hubcentric ring. the front is a whole nother story. im not sure what size spacers im gonna need...anybody know what i should run? the offset is et40. i was surprised when i got it to fit in the back with no spacer and i test drove it, didnt hear a thing. its close to the trailing arm, id say an inch or inch half. it already came with rings.Comment
