spray can clearcoat on wheels??
  • heiman5
    • Mar 2006
    • 251
    spray can clearcoat on wheels???
    hey I am trying to use a spray can style clear coat on aluminum wheels... parts of the wheels are chromed... and when I spray them with very light coats over and over they remain grainy and rough looking and feeling... likke a light dusting of sand lol. Any tips for how to clearcoat with a can ... its a polyurathane. idk i have gone through two cans ahaha and have only one wheel looking nice cause i keep taking it off after when get pissed off. any ideas/tips/alternate plans greatly appreciated!!!
    For Sale: $8k ;)
  • erik325i
    • Jan 2005
    • 3567
    I have found that unlike paint cans, clearcoat should be sprayed with heavier wet coats to achieve a smooth glossy finish. If you spray light coats, you will get that rough texture.
    I'm not a paint pro though, so my method could be completely wrong...
    -Erik
    • blueapplesoda
      • Dec 2005
      • 1904
      spray until its glassy, but not dripping.
      • DarkWing6
        • Apr 2004
        • 7144
        The problem with applying heavy coats of spray can clear is that it can tend to yellow and crack.
        • AndrewBird
          The Mad Scientist
          • 11898
          For better atomization, put the can in warm water for 15 minutes before you spray. Heats the paint up and makes it spray better. Make sure the water is not too hot or else you risk exploding the can. You want it hot, but cool enough to comfortably put your hand in it.
          • Dave
            E30 RAT
            • 11675
            If the humidity is high where you are doing this - it can cause a problem. Do rattle can work in lower humidity for a better result.
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
