I jacked up the rear end of my new-to-me '91 325i tonight because I've been hearing a rubbing/grinding noise from the back end of the car on slow speed turns in the parking lot, for example. I've read that this could be because of bad wheel bearings and also potentially a failing differential. I had seen on "wheeler dealers" that the mechanic was grabbing a wheel and was able to shift the wheel by tugging on it. I can't do that to either wheel... is that a valid method or should I try something else before moving on to the diff?
I can swap the diff fluid out, watched some youtube on that and it seems super easy with a torque wrench and see if that helps too.
