Well i ordered the PR1's
  • s52e368
    • 539
    i ordered the pro race 1's at a local shop for the ridiculos price of 500$
    15x7
    et30
    they actually came in of friday so ill be picking them up this week and mounting S03's on em..
    i cant recall anyone having these on the board so ill be posting pics asap.
  • s52e368
    • 539
    did a quick PC (im picking these up today)
    • 2002maniac
      • 4260
      what size spacers will you use?
      • C ///M
        • 1040
        Those wheels don't need spacers or hub-centric rings. They come in direct fitment for e30, 15x7 et25, 4x100, 57.1.
        What color did you get? Black?
        332iS R.I.P.
        • 2002maniac
          • 4260
          Originally posted by s52e368
          15x7
          et30
          Actually he needs spacers if he's putting 225's on there.
          • Mystikal
            Wheel Fitment Expert
            • 9602
            I would argue, but 225 S-03's are WIDE. I know they won't work on 15x7.5" ET25 Ronals, I doubt they'll work on ET30 wheels.
            • s52e368
              • 539
              actually i dont need spacers.. im running 205 S03's
              and yes they are black.
              • C ///M
                • 1040
                Are you sure they're et30? E30 fitment is listed at et25.
                332iS R.I.P.
                • Dave
                  E30 RAT
                  • 11675
                  Hosting the pic for Doug Hitchcock. Red with black PR1s.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • Erisa_1974
                    • Jun 2006
                    • 25
                    15x7 et30 PR1s are usually for Miata's, with a 56.1mm centerbore (little tight)...
                    • s52e368
                      • 539
                      zing !!
                      i did buy these and theres a local wheel shop that will shave the center bore for me...
                      the reasoning was:
                      price 125 shipped (500 out the door mounted and balanced locally)
                      availbility they had them next day.
                      all the other carriers of the spec e30 wheel are on backorder.
                      • s52e368
                        • 539
                        finally got these things on...
                        15x7 td pro pace 1 wheels 13lbs
                        et 30mm
                        54.1mm center bore (miata)
                        had them bore out to 57.1mm for the e30 cost 80$ which is cool cause i saved a ton of money on these getting local.
                        had to get a 5mm spacer all the way around because of the 225/50r15 ( potenza pole position S03) tires
                        so heres the skinny (exactly) :
                        500$ (wheels)
                        80$ (bore)
                        20$ (5mm spacers)
                        16$ (discount tire/lug bolts slightly longer than stock)
                        100$ (extreme low mileage S03's)
                        716$
                        • s52e368
                          • 539
                          i ordered some rrt studs should here today
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Now drop that thing! So no to 4x4.
