15 x 8 et 20..who runs that?..
  • JRKOUPE
    • Dec 2004
    • 3159
    I just want to ask y all a few questions on your fit issues, if any.
    i just played w/ my 15/7 et 25 on a 225/50 and used some spacers...18mm worth.......Ill def need a roll at least. I didn't do the frts yet.
    15/7 et 25 vs 15/8 et 20 is about 18mm more in the "outward" direction. 5 mm of offset plus around 12.7 mm on each side( inner and outer).....about 8 mm more inward.( 12.7 -5)
    Im not even aware what issues may be on the inboard side?.......like hitting the strut housing?
    how is your set up fitting?
  • NateE30
    • Nov 2013
    • 47
    I'm running 15x8 et 20 with 225/45 rivals. I had to do 8mm (i think) spacer in the front to clear my megan coilovers. And I had a 5mm spacer I threw on the back. I rolled the rear fenders but ran for over a year not rolled with minor rubbing. The front I left alone haven't rolled I only have minor rubbing at full lock because of the M3 cabs. Hope that helps ask more if you need.
    • JRKOUPE
      • Dec 2004
      • 3159
      that helps a bit.
      I know 225/45 is shorter..
      y did u use a spacer in rear?
      any pics of car/set up?...
      thnx!!!
      • LJ851
        • 7919
        I run 225/50 on 15 X 7.5 ET25 Ronals . The tire is pretty close to the strut housing and a "wide" 225/50 can touch the housing with these wheels.
        No spacers, no rolling, no rubbing. Fairly tight all around in the front, plenty of room in the rear. H&R race springs.
        Lorin
        The M30 is God's engine.
        • NateE30
          • Nov 2013
          • 47
          I put the spacer in the rear cause i had it, no reason but that. I try to get some pics. I don't have anything the really shows tire fitment.
          • JJe30
            • 2044
            I just bought 225/50 for my Ronal LS
            • dasmanschaft012
              • Apr 2014
              • 642
              my understanding is that 15x8 et20 would be a perfect fit with 225/45/15, no spacers necessary.
              i'm fine with rolling/pulling fenders, maybe i need to go more like et15?
              We're in deep now boys
              1988 325i SETA - Daily driver
              1988 340iL - Track car
              My M60 V8 swap thread here
              [oo==OO==oo]
              • JRKOUPE
                • Dec 2004
                • 3159
                I ran those wheels....w/225 50 ra 1..Iwasthisclosetostruts
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  ahh...cool
                  • blazinxpk
                    • 839
                    Billy sport shocks
                    IE3 springs
                    E90 drophats
                    15x8 +20
                    225 45 15 BFG Rivals
                    Fits perfect. No rubbing. Didn't have to roll/pull.
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      look good....
                      due to the shortness of a 225/45 vs 50, Id need to shift a lot more on certain tracks.......that would suck.
                      hmmm
                      • dasmanschaft012
                        • Apr 2014
                        • 642
                        Originally posted by blazinxpk
                        Billy sport shocks
                        IE3 springs
                        E90 drophats
                        15x8 +20
                        Perfect, thanks for the input. :)
                        I'll have a similar set up, but with Konis and H&R races.
                        [oo==OO==oo]
                        • blazinxpk
                          • 839
                          hmmm
                          how big of a difference would it really make?
                          Just make sure to request stick on weights as opposed to clip on weights when getting the wheels balanced. There is minimal clearance between the strut housing and the wheel. My clip on weight would hit the strut housing under hard turns. Stick on weights solved this issue completely.
