Hello everyone! So I've checked throughout the web and I'm pretty sure I know the answer, but I want to double check with everyone on here.
Late model e30 is lowered on Bilstein and H&R springs. Might eventually put drop hats in the front as well.
I'm thinking about buying a set of wheels.
16x8 et 11 5x120 bolt pattern hub bore 74.1.
If I use 42 Draft Adapter's, 4x100 to 5x120 (8mm,10mm,13mm,15mm) thick adapter with proper e30 hub bore to wheel hub bore.
I know people run 16x8 et 0
Will I be able to make the stated wheels fit?
What thickness of adapter do I need to go with?
I'm necessarily shooting to get a 16x8 et 0 spec, I want the best fitment setup.
Suggestions or advice would be greatly appreciated!
Gibbsinc
Gibbsinc
