HELP Wheel Fitment DOUBLE CHECK
  • gibbsinc
    • Mar 2013
    • 152
    Hello everyone! So I've checked throughout the web and I'm pretty sure I know the answer, but I want to double check with everyone on here.
    Late model e30 is lowered on Bilstein and H&R springs. Might eventually put drop hats in the front as well.
    I'm thinking about buying a set of wheels.
    16x8 et 11 5x120 bolt pattern hub bore 74.1.
    If I use 42 Draft Adapter's, 4x100 to 5x120 (8mm,10mm,13mm,15mm) thick adapter with proper e30 hub bore to wheel hub bore.
    I know people run 16x8 et 0
    Will I be able to make the stated wheels fit?
    What thickness of adapter do I need to go with?
    I'm necessarily shooting to get a 16x8 et 0 spec, I want the best fitment setup.
    Suggestions or advice would be greatly appreciated!
    Gibbsinc
    89 - 325i now
    91 - 325i RIP
    99 - e36 M3 then
    89 - 325i then
    98 - e36 M3 then
