16x9 et15
  • AngeloF10
    • Dec 2015
    • 191
    16x9 et15
    my esm 16x9 et15 rears are rubbing bad. 225/50/16 tires.
    those of you running this setup, have you been able to squeeze these in with just a fender roll?
    or are you adjusting rear camber with a kit? how is your tire wear?
    -Angelo
  • htx_e30
    • Sep 2014
    • 132
    225/40 is how I fixed the problem
    • Nick's e30
      • Mar 2012
      • 676
      -Angelo
      My setup:
      16x9 et 15 ESM00? (CCW lookin ones) on a late model vert.
      205/45/16 Federal 595 tires w/ fender roll. No pull, no cambergang -10 bullshit, no spacer, nothing else. I barely clear the fender.
      No antenna? I sell plugs!
      Here: https://www.r3vlimited.com/board/sho...77#post4937877
      • AngeloF10
        • Dec 2015
        • 191
        How is the stretch with 205 on a 9 inch wide wheel?
        Sent from my LG-H810 using Tapatalk
        • htx_e30
          • Sep 2014
          • 132
          Stretch is barely there on a 205. Minimal if anything. This was my 195 prior to new wheel setup on a 9" for reference. The 205 was much less
          • g.ruff561
            • 1264
            Next set try 225/45/16. I have been running them on 16X9, Et 15 for years....... G.
            • MC Hammered
              • Jul 2008
              • 2076
              215/45/16 here
              215/40/16 on top for comparison which had too much stretch and I didn't want to run that low to make the fender gap look right.
              My 1989 e30 s52 Touring... this is Betty
              My 1989 325i vert (sold)...this is Nina
              My 1991 M5 (sold)... this is Veronica
              Photo comparison: OEM vs aftermarket windscreen for a convertible
              • AngeloF10
                • Dec 2015
                • 191
                I know you all warned me about this but tire selection sucks for these sizes.
                • AngeloF10
                  • Dec 2015
                  • 191
                  Thanks for everyone's help. My buddy has a shop so he put the 205 \50 on the rears and rolled the fenders and it is at least drivable with rubbing in aggressive turns. I ordered 205 \45 for the fronts for a little more clearance. If I can't live with the rubbing, I'll probably just get 2 more 205 45s. I purchased the conti dws' and the only size selection is 205 with the 45 profile.
