Was looking at 25mm spacers for the e30 and found this pair on eBay. They are for a Saturn which also have 57.1 center bore. The only issue I found would be converting to lugnuts as opposed to using lug bolts or the stock bolts not fitting the holes in the spacer.
Would this be an idiotic idea? And would using lug nuts opposed to bolt be an issue?
Link to the spacers.
http://m.ebay.com/itm/4X-Hub-Centric...877?nav=SEARCH
-james
-james
