Can I run these tires on a 16x8.5 with just springs on the car or will it rub even if the fenders are rolled and pulled
225/40/16
Tags: None
The front is +19and rear is +13 I wanna put a beefy tire on it and wanna know what will fit what looks the best and won't rub with the springs I have on it right nowsigpic
225 40 16 is a smaller diameter than the stock tires on bottlecaps.
To me, a beefy tire would be 225 50 16 which would be more of a thick sidewall and wide track. Like this:
16x8 et20 ESM 002R's with 225/50r16 RS3's
Check this site out:
Use our wheel offset calculator to visualize the new tire position when changing wheel and tire sizes. Convert wheel offset and backspacing to calculate the correct setup for your vehicle.
Great visual on tire/wheel comparisons and has offset comparison too. May help you out.Last edited by badwella; 01-20-2017, 07:33 PM.P.O.S 1989 325is - aka Project Sh*tbox
Project Shitbox - Restomod and other stuff - soon to be 328isComment
