Spacer Noob Questions.
  • HerbE30
    • Nov 2015
    • 538
    I am finally looking at wheels guys! Oh joyous days! I just have a few questions in regards to spacers and such.
    I am looking at 16x8.25 et25. So I'm guessing 10mm/15mm front/rear. When I buy spacers I know that the spacer meeting hub diameter has to be 57.1, so do I have to buy hub-centric rings to mate the wheel to the spacer perfectly? As in buying spacers and hubcentric rings??
    Will this clear factory struts?
    I found a pretty fresh look I hope...
    Bore on the wheel is 78.1 if I recall correctly.
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • HerbE30
    • Nov 2015
    • 538
    Just to bump this and clarify my questions.
    This is how I assume I will have to run my set-up.
    From the Hub > Spacers > Hub-Centric Rings > Wheels > Extended Lugs???
    Or do I need the rings?
    20% Accurate
    • HerbE30
      • Nov 2015
      • 538
      I figured it out. I will have to had centric rings to the mix. Now my hope is that the bolts fit in the wheels...
      20% Accurate
