will 16x7 with 38 offset fit
  • quillbro
    • 369
    Originally posted by Mystikal
    The Konigs will fit without spacers, but they won't look great. 15mm spacers would make them look nice.
    SWEET!!! Thanks for the tip.
    So spacers from tunnermotorsports? Also what size tired do you recommend for this size wheel.
    Also is $600 a good price for these wheels?
    • 318wa
      • Sep 2006
      • 16
      Does it say on the wheel somewhere what the offset is?
      • browntown
        • Jun 2004
        • 3524
        look for a stamp or casting that say etxx with x's as numbers. The numbers are the offset. Sometimes that marking is on the back, the inner lip, inbetween lug bolt holes, etc. example et35 is offset 35
        • 318wa
          • Sep 2006
          • 16
          it says et40 then some other numbers so the offset is 40? What kind of spacers would I need for that offset?
          • M42Technik
            • 9781
            Okay. That is a good price for those wheels.
            Shoot for ET20. Offset 20.
            The end.
            Reminiscing...
            • browntown
              • Jun 2004
              • 3524
              for good ole 205 wide tires on a 7" wide rim, et40 - 15mm spacer = 25 net offset should work fine. Sounds like a honda wheel. You'll spend a good chunk of change on 15mm spacers and longer wheel bolts.
              • Mystikal
                Wheel Fitment Expert
                • 9602
                They were like $450-600 NEW. Values have actually appreciated since supply is cut off.
                Pay if you like them.
                • 318wa
                  • Sep 2006
                  • 16
                  Where is a good place to get the longer bolts. Anybody know how long I would need with 15mm spacers? Im going to try and make the spacers myself I work at a machine shop.
                  • M42Technik
                    • 9781
                    Be safe and get real hubcentric spacers from a reputable company, Mr. Jay above can help you in that department, I try to avoid spacers (for $$ reasons).
                    Reminiscing...
                    • 318wa
                      • Sep 2006
                      • 16
                      Hubcentric just means that the bore on spacer is the same size as the hup so there is no slop. I can just measure the diameter of the step in the hub and make my spacers according. Would be made on a cnc just like the ones I would buy from somewhere.
