Tire sizes: 205/50/16 or 225/45/16 on 16x8
  • quanaman
    • Dec 2016
    • 231
    Hi all,
    I’ve done a bit of research here and it seems not many people have a solution for my specific scenario. And if they did, it was years ago.
    I understand that most people recommend a 225/45/16 tire, however the options for those are few and they are expensive. 205/50 are much easier to find and are and more affordable. Which brings me to my next question.
    The car is a 90 early mode vert with Koni suspension and h&r sport springs. Slightly lowered, nothing crazy and is sitting on bottle caps. I want to get either 16x8 +15 or 16x8 +20 all the way around. The car has early model wheel arches which i understand are bigger in the back. Would I be okay on the 205/50? Ideally, I’d like a squared setup. I thought about a 16x9 in the rear but i also have 20mm spacers if needed i could use to push the back out. But I’d rather not.
    Thanks!!
  • E30335i
    • Feb 2014
    • 1035
    I have 225 45 16
    16x7.5 et 20
    16x9 et 15
    I would rock 225 all day on a 8
    There’s a slight hill on the front right tire
    I’m tucking as well.
    • E30335i
      • Feb 2014
      • 1035
      Wanted to add I have no spacers and I used to have 205 50 but looks ugly compared to the 225 45
      • quanaman
        • Dec 2016
        • 231
        What tires did you go with ? I can only seem to find the toyo’s Currently for almost $600
        • E30335i
          • Feb 2014
          • 1035
          Nexen it’s like 76 each. Can use that to see your spacing for your fenders, don’t want to spend top dollar for your tires you can’t use
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5616
            I’m rocking 205s and they look good
            • quanaman
              • Dec 2016
              • 231
              That does look really good. How low are you or what are you lowered on? Wheel specs?
              • quanaman
                • Dec 2016
                • 231
                I’m leaning toward pulling the trigger on a set of 16x8 +20 xxr 531 with 205/50/16. If anyone has pictures of a similar setup/firmware I’d really appreciate it
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5616
                  H/R race, e90 hats, billy sports.
                  16x8 et20
                  Dunlop DZ102 205/50 16
                  • LowR3V'in
                    • 4209
                    ^ does it rub if you use the 225 and is that on the inside or out?
