wheel hub and bearing replacement issue
  • posix
    • Oct 2018
    • 63
    i just "finished" a front wheel hub and bearing replacement on my e30.
    When i tightened the the wheel nut, the hub was no longer able to spin. I dont think i tightened it too much, didn't even use a torque wrench... did i mess up the wheel hub during installation?
    only thing i think i might have messed up was I was pounding the hub with a wooden block instead of hitting the inner race. could that have messed up the wheel bearing assembly ?:?
  • AndrewBird
    The Mad Scientist
    • 11898
    Will it not spin at all? It should have a little bit of friction, but not a lot. It's possible hitting the face of the hub could have damaged the bearing. The inner cage is plastic and can break. The bearing should just slide on, no hammering needed. A light sanding of the spindle with emery cloth should allow the bearing to slide on easy. A little anti-seize never hurts either.
    • posix
      • Oct 2018
      • 63
      I haven't put the wheel on, but when tightened to spec torque, it doesn't spin. If i loosen a bit, then it spins properly.
      • Pootis
        • 636
        Doesn't sound like it is completely seated
        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
        • posix
          • Oct 2018
          • 63
          mmm, could be. i'll try to hit the inner race a bit more and see if that helps
