BBS RMs on Stock 325i
  • 94530inh
    • 66
    I've been on the hunt for reasonably priced BBS wheels for a while now.
    I just picked up a set in need of refurbishment on craigslist. These are the Volkswagen BBS RM012s. I've ordered new hardware and 2 inch lips which brings these wheels to 15x8 all the way around.
    In researching the sticky I found out that the wheels will be the following spec once I've installed the new lips.
    15x8 et14.95 -- Now I need to figure out which spacers to use and what size tires to go with. I'd like to drop the car 2 inches max. Eventually.
    Any suggestions on tire size? Would a 10mm spacer be the best way to go? Would I need longer studs?
    Thanks in advance!
    65k 325i Automatic
    1985 M635CSI Frank Fahey Stroker
    1970 BMW 2002 (in restoration)
  • kronus
    • Apr 2008
    • 13032
    15x8 et15 is just about right actually, I don't think you need spacers unless you're aiming to HeLlA PoKe BrO
    cars beep boop
    • word is bond
      • Apr 2012
      • 503
      You shouldn't need any spacers. 225/45 or 205/55 should be good. Depending on the tire, 205/55 is not really stretched. I ran 205/50 BF Goodrichs on 16x8 and they looked meaty. 225/45 is nice and wide but the overall diameter is a little smaller (not much).
      willtheyfit.com is a good starting point. Check your set up against the two stock sizes: 195/65/14 on 14x6.5et33 or 205/55/15 on 15x7et24
      diamantschwarz 1991 318is
      • Mike36
        • 1079
        You may want a 5mm spacer in the rear to even out the front and rear fitment. Fronts will actually be perfect though.
