15x8" wheels 20mm offset
  • joshh
    • Aug 2004
    • 6195
    These wheels will fit the E30 and they are 15x8. They will be going up in cost a bit but right now they are a great price.
    They sell them with the 225 45 15 RS-2 Hankooks if you want.
    It's a Honda site so don't wet your pants.
    http://www.honda-tech.com/zerothread/1802720
    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
  • Brian D
    • Mar 2006
    • 832
    Promising, but it kind of looks like the center bore is 59.1 mm only. I sent the seller on ebay a message, I'll report back.
    1973 Bavaria
    • Dave
      E30 RAT
      • 11675
      Looks promising if they are not too soft.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • Brian D
        • Mar 2006
        • 832
        I got a quick answer back, that's kind of nice. 59.1 mm, and no centering rings available. I looked at 1010 tires and they don't list any for 59.1>57.1 either. They do look pretty nice though, only 13.4 lbs.
        Full answer from the seller:
        59.1 only. No centering rings needed for a race wheel. I designed the wheel with the smal center bore of 59.1 to retain more material in the mounting pad. That extra material allowed me to make the pad thinner to reduce weight while actualy making the wheels stronger. As opposed to most generic aftermarket wheels with huge 73mm bores and thick centering rings. The 73 bore is a default for 5 lug cars so wheel makers use that bore for every bolt pattern even though it is not optimum for the 4x100.
        1973 Bavaria
        • Dave
          E30 RAT
          • 11675
          If you are runnig with wheel studs, I think you'd be fine with these. I thought I needed rings with my Moda Sports - then I ran a weekend at MidOhio without them (high speeds obviously) and was just fine. No wobbling, no roughness, etc.
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • Brian D
            • Mar 2006
            • 832
            Thanks Dave, that's been my experience with other makes of cars but everyone on BMW forums make it sound like the car is exceptionally sensitive to non hubcentricity.
            Very promising, indeed.
            1973 Bavaria
            • Dave
              E30 RAT
              • 11675
              As always, YMMV.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Brian D
                • Mar 2006
                • 832
                14 page post at Miata.net. http://forum.miata.net/vb/showthread.php?t=171902
                1973 Bavaria
                • 2002maniac
                  • 4260
                  those look promising. I'm interested in the 245/40/15 Avon's he plans on importing!
                  • Brian D
                    • Mar 2006
                    • 832
                    Not that anyone gives a shit, but the +20 offset has been canceled.
                    1973 Bavaria
