the wheels pictured on the rabbit are 13x8 et 4 with a 175 50 13.. and yes this is the one and only pineapplegti from the tex lmao
konig rewind
We make two-piece minilight replica's for Porsche (ST racers in the early 70's had Minilights on the rear). We can do custom backspacing/offsets, 4x100, 57.1 hubs and they come in 15", 16", and 17" sizes.
They are not cheap, but they are available if you like the look.Comment
i figured as much -- i did the same 'poking around' like u did earlier this year.. same result--Hayden--
'87 325 coupe- Trak Rat
'93 318is- 4cyl's of fury
'92 Integra GS-R--yeah, its fast..
www.G2IC.com
Wow there's a 16x7" ET25 Superlite wheel there. That is a perfect fit for E30's...
There is also a 16" Sportmax 002 available in a 4x100 version apparently.Reminiscing...Comment
im confused about what you guys are not finding? here is the 15x7 4x100 et0 Konig rewind http://www.konigwheels.com/catalog_p...ID=1&ss_id=405
where is the centerbore listed, i cant see to find that anywhere?
edit: i must be tripping, i could have swore i saw it say 4x100 somewhere....Comment
Actual Panasports on BFC
Pretty good price if your into refinishing wheels yourself.
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.Comment
The +20mm offset 4x100 Rewinds were a special order we had made for E30's. They're 73mm hub bore, and take a standard 73 to 57.1 hub ring to be hub centric on the E30.Comment
Sorry for the old bump, but I'm still curious about these wheels. I found a site selling 15x7, 4/100, offset of 20mm. This would be the correct size, right?
http://www.1010tires.com/wheel.asp?w...RWD+%2D+SilverComment
http://www.1010tires.com/wheel.asp?w...RWD+%2D+SilverReminiscing...Comment
Thanks a lot. :)Comment
