Proper inflation #s?
  • bmwm3n528
    • 3654
    I guess there's no concrete answer, but wondering what you guys might use that have 205/50R16s or something similar.
    At the moment I've been running 33F/36R without any real significant tire wear, and seems to be provide relatively neutral handling. Just wondering though.
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
  • ldsbeaker
    • Aug 2004
    • 3098
    I have a similar question, but have no idea. I run 32 F/R. 205/50-15 on Euro Weaves.
    Slicktop City!
    • 92 mtechnic cabrio
      • 4907
      40 in the front
      80 in the back
      V...end result...V
      R.I.P 07/01/09 - 04/23/10 :(
      • 808BMW
        • 2910
        Tire pressure depends on the actual tire itself, size, use, and driving style.
        I usually run 35-40 psi F/R and I never stagger my pressures (especially so much)
        On low-pro tires, I try to keep the pressure around at least 40, gives a bit more rim protection.
        Whatever you do, read your tires and make sure you know the max inflation, and never fill them up too far
        • MikesJo
          • Mar 2004
          • 989
          I'm doing the same, either 31 or 32 psi on euro weaves 205/55/15 tires.
          Vancouver Portrait Photographer
          E30 M3 Wallpapers
          • PeaveyBassist
            • Sep 2004
            • 3511
            32-34 psi.
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • bmwm3n528
              • 3654
              Originally posted by PeaveyBassist
              32-34 psi.
              Will
              w/bottlecaps?
              Believe the specs are on the door jamb for original wheels.
              Trevor Ely
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Eh, it's not that simple.
                Optimal tire pressure depends on a lot, for example:
                o Tire model
                o Tire size
                o Suspension (geometry, compliance, etc)
                o Road condition
                o Desired use (road, track, auto-x, drift, etc)
                o More...
                Really you just gotta feel it out for yourself, on your own car. Other's numbers aren't very useful.
                • ldsbeaker
                  • Aug 2004
                  • 3098
                  I was afraid of an answer like that. Thanks.
                  Slicktop City!
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    Yes, I was on bottlecaps. Everyday use I run 32-34psi but it doesnt bother me if its anywhere between there. Autox with Azeni rt615's I ran around 45psi cold or so and once heated up they are usually around 47-48psi.
                    Will
                    DaveCN = Old Man
                    • bmwm3n528
                      • 3654
                      o Tire model
                      o Tire size
                      o Road condition
                      o More...
                      Yeah, I'm aware that all these conditions come into play, was kind of looking for a range more or less that might be good for my tire size listed.
                      Anyway, yeah...It's hard to give a concrete answer.
                      Trevor Ely
                      • MIKe30
                        • Sep 2006
                        • 2334
                        ok... noob question but w/e, dont know if you dont ask.
                        where it says max pressure (i think some say under load? not sure) is 35psi, but when you put it at like 33 or 34 and still doesnt look full, wtf do you do. go to 35, or leave it at what it is and say its safer that way?
                        i leave it at 33-34 for daily use on city and highway driving.
                        any input?
                          • 4907
                          what size tires are they? Maybe the load rating on them are too low for your car
