Would these fit?
  • EWAustin
    • Sep 2006
    • 234
    Would these fit?
    13x8 Rota RB wheels.
    Offset: +4
    Backspace: 4.5"
    Weight: 14 lbs
    Lug Pattern: 4x100
    Center Bore: ? (larger center bore, should fit almost anything)
    Not for daily use of course, but I was thinking for a set of Autocross tires.
    Oh yeah, IE3 springs on an '87 325is
    Eric Austin
    1990 325i Sterling Silver
    ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
  • BahnE30
    • 1050
    i doubt they would clear the calipers...
    • 2002maniac
      • 4260
      Trent could rock them on his 318
      • EWAustin
        • Sep 2006
        • 234
        how close are the stock 14" wheels to the calipers?
        Eric Austin
        • 808BMW
          • 2910
          Pretty close, a test fit is definately needed.
          I've heard of 13's being done, but it depends on the inside shape of the rim.
          • DanGillan
            • Mar 2004
            • 4061
            i've personally made 13"s fit on an e30. but it took some spacing and long studs. clearly you'd need to test fit.
            Dan
            • O 16581 72452 5
              • 1066
              If it's an internet transaction, i'd stay away and wait for something else. They're more likely not to fit than fit.
              • Rocla
                • 922
                I tried numerous of 13" steelies... in front ~40mm spacers would be required with any STEEL 13" wheel. Rears are easy.
                But why 13"? What size of tyre? 195/70/13 would have way too high sidewall(=ugly) and still be too small radius and anything lower would just be too small anyway.
                EDIT: 195/70/13 would be too narrow too on those rims?
                Current:
                BMW 320i 2d 2.0 m20 -88
                BMW 325i Cabriolet 2.5 m50 -88
                BMW 316i touring 1.6 m40 -90
                BMW 320i 4d 2,2 m54 -01
                • 2002maniac
                  • 4260
                  I'm sure these would be for racing only. There are plenty of wide 13" slicks and DOT R-comps available.
                  • EWAustin
                    • Sep 2006
                    • 234
                    If I get them I'd go for 215/50-13 Kumho V710s, The seller is an aquaintance of mine, so I'd be able to test fit first.
                    Hmm, I've got some Scirocco 16v seats he wants, maybe he'd trade me...
                    Eric Austin
                    • 808BMW
                      • 2910
                      If you can test fit em, then by all means go for it
                      • e30frosh
                        • Dec 2004
                        • 2170
                        I absolutely love the look of those wheels, and sound that konig made a similar set in 16's I think. Saw em on the bay. Want 'em...but all my cash is tied up in the stroker...I vote test fit and then post pics!
                        Every day I wake up we drink a lot of coffee and watch the CNN
                        Every day I wake up to a bowl of clover honey and let the locusts fly in.
                        Lobsterbacks attack the town again
                        Wrap all my things in aluminum
                        Beams of darkness streak across the sky
                        Pink rays from the ancient satellite
                        Every time I look out my window same three dogs looking back at me.
                        Every time I open my windows cranes fly in to terrorize me.
                        • joshh
                          • Aug 2004
                          • 6195
                          The caliper isn't the problem, the tie rod is. The tie rod sticks out further than the caliper does.
                          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                          • Rocla
                            • 922
                            Both yes, but with most of the 13"steelies, as I said the caliper.
                            Current:
