the correct offset.
  • Tree18is
    • Mar 2004
    • 2703
    the correct offset.
    whats the max amount that will fit on our cars?
  • Tree18is
    • Mar 2004
    • 2703
    dont reply to this,
    its in the wrong sub forum
    • Van Westervelt
      • 9365
      Fit or function? Gotta tell us some more, factory setup? 5 lug? YOu can always go to a higher offset and run spacers. 20-25 is ideal.
      Ok yeah, SEARCH!!
      • O 16581 72452 5
        • 1066
        I'm going to reply anyway since you got me here, bitch.
        It depends on the width wheel you're running, 0 offset can be pulled off if you're doing under an 8" wide wheel with fender rolling, alot of guys run 9" with a 0 offset, but it requires a huge tire stretch.
        As fas as offset towards the suspension side, i can't exactly say, probably a 25 is about ideal in a 7" and around 15 on an 8", once you get into 9", you must go to around 5.
        • Tree18is
          • Mar 2004
          • 2703
          thanks alot, i mean i want function. but i just want them to be right at the fender ( not hitting) . but this post is old so im sure its forgotten allready.
          BTW: 4lug 318
