More Ronal LS questions
  • mrl325i
    • Oct 2006
    • 170
    Will 225/50R15 tires fit OK on my stock suspension 325iC?
    Anyone have a pic of Ronals on a stock car with 225s?
    Thanks!
    Mark
    88 325ic
    03 325i
  • DEV0 E30
    • Oct 2004
    • 8892
    Thanks!
    You should be more than fine on stock suspension I would think.
    Any idea on what exact tires you are getting? I have no problems with 225/50 Yokohama ES100s on mine. Some tires run wider than others but again, I'm pretty sure you'll be fine. I've never felt any rubbing.
    Ground Controls, Rates: 375/475
    • mrl325i
      • Oct 2006
      • 170
      I am planning on Kumho Ecsta ASX or AST tires. I currently have ASXs on my e46 and I am very happy with them.
      Mark
      88 325ic
      03 325i
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Last I checked Kumho doesn't make a 225/50/15 street tire.
        Some 225's will be okay, some will not. If you liked the ASX, try the Falken ZE-512. Excellent tire, and it runs narrow; you'll be fine with 225's.
        • 2002maniac
          • 4260
          depends on the wheel, but they will most likely fit fine.
          edit: haha, duh! I forgot the title of the thread. yes they'll fit great.
          • mrl325i
            • Oct 2006
            • 170
            The ASX does not, but the AST does come in that size, and it is only $53 at Tirerack.
            My concerns are twofold: that the 225 actually fits on the wheel, and that the 225 does not rub on any part of the car.
            Mark
            88 325ic
            03 325i
            • Mystikal
              • 9602
              Ahhh, new stuff. See, this is why I mention "last time I checked". And I'm on Tirerack weekly just about, it must be a new size offering.
              Check the section width of the 225/50/15. If it's more than 9.2" on a 7" wheel, you may have issues. I severely doubt an H-rated all-season would be that wide though, only extremely aggressive summer gear is.
              • Massive Lee
                • Sep 2006
                • 6785
                A few years ago, I had ACT LS 15" x 7.5" et25 and 225.50.15 TOYO RA1s on my Hartge H23.
                That was a great set-up. If you track your car, the rear tires will slightly rub the inner well under compression. Nothing major, and that is a very common occurence. You will only notice a skidmark on the metal that will be polished a bit. Don't worry.
                massivebrakes.com
                • mrl325i
                  • Oct 2006
                  • 170
                  Thanks for the info. Looks like I'll stick with the recommended 205/55 tires. According to Tirerack, the 225 Kumhos might have fit problems.
                  Mark
                  88 325ic
                  03 325i
                  • CarsSuck
                    • Oct 2005
                    • 968
                    I run a 225/40/16 hankook ventus whatever. No rubs with H&R sports. If you dont do a lot of performance driving, stick with the 205. They'll be lighter and narrower so better acceleration and better gas mileage.
                    --Will
                    • Mystikal
                      • 9602
                      Don't listen to Tirerack, they are ultra-conservative.
                      I just looked up the tire specs, they are 9.2" on a 7". Run the 225's if you'd like.
                      • mrl325i
                        • Oct 2006
                        • 170
                        My car has stock suspension, and it is gonna stay that way, so I'll just keep it stock-sized on the rubber, too.
                        Mark
                        88 325ic
                        03 325i
                        • mrl325i
                          • Oct 2006
                          • 170
                          TR guy said with 25 offset they might rub fenders.
                          Mark
                          88 325ic
                          03 325i
                          • Mystikal
                            • 9602
                            Fair enough. If you want to be 100% certain they won't rub, just get the 205s.
                            FWIW, I have ET20 with 225's and they dont rub. ;)
                            • mrl325i
                              • Oct 2006
                              • 170
                              I would probably be fine, but there is so much debate on the boards and conflicting info about what brands fit and what don't that I am just going to take the easy way and go for the OEM size. Thanks for the input.
                              Mark
                              88 325ic
                              03 325i
