Originally posted by GThomas
View Post
This is a sticky topic.
Originally posted by JonnyOg View Postquote from craigslist
"F/S BBS RS 16"X8" and 16"X9".
ET 45 (offset)
Bolt pattern 5X114.3"
Would these fit an e30 without modification, besides fill and redrill ofcourse.
Originally posted by ProjectCab View PostThese will not fit an e30 without modifactions/spacers
The front would be 6.3" of backspacing. You have about 5.5" MAX to play with before you hit the strut. so you would need a 20 -25mm spacer, stretch and pull. (maybe no pull depending on stretch)
For reference, Even the ESM 16x8" et20 sometimes does not clear the calliper and that has 5.3" backspace
The rear would be 6.8" and I know for a fact you cannot have any more than 6" of backspacing in the rear. You might be able to get away with running a 20-22mm spacer but its a tight fit and will probably require stretch and pull as you are now essentially running 9.8"-10" wide with et25
Originally posted by limp mode View Postjust got some wheels 16x8.5et15 all around with a 205x45 falkin 512. what is the lowest possible offset i could run to make these agressive as possible. ill be rolling my fenders. and will be dumped. thanks dude ! i was thinking et0 all around or -5rear?
Originally posted by Mystikal View PostThey're already near ideal to me. Mount them, take measurements, and add spacing as you wish. I've seen the offsets you mention work, but usually with 205/40s and a lot of rubbing.
Originally posted by Mystikal View PostBackspacing is for strut clearance and has nothing to do with caliper clearance. 6" of rear backspacing is not the maximum, especially for larger wheel diameters.sigpic
Originally posted by Mystikal View PostAt +13 in the rear you're limited to a 205 unfortunately. The 22mm spacers will work all around with the 205 tires. If you want 225s you'll need 15mm spacers for all four.sigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/
Originally posted by GThomas View PostThanks for the help, is there any advantage to running the 225/45's over the 205/50's as far as grip goes or would their be more roll over on 7" wide? Also these would be used mostly for auto-x.
Originally posted by lhigorpvl View Postso i have an e30 89 vert, i have 17" on them right now, with winter around the corner, i would like to put the basketweave 14" rims back on with snow tires. So my question is: What size tires r the best for winter, i want it to feel like AWD lol thanksss
