Originally posted by e30edward
View Post
This is a sticky topic.
Originally posted by surebimmer View PostWill 17x8 et 20 and 17x9 et 22 with 235/40 17 Hankook rs2's fit? I know I will have to roll the rear just a little more then I have now. But not sure on the front.
Running 16x8.5 et20 front and 16x8.5 et22 with 225/45 16 rs2's now.
The new rear setup will be 0.4" wider as well as 0.5" taller, so you'll need to push the fender out accordingly.
Originally posted by deansbimmer View PostOK. I got a set of 16x9 Borbet and can pick up some BFG G-Force Sports. Do these tires stretch ok? The fitment I am considering is:
215/40/16 in the rear.
205/45/16 in the front.
I sit on coilovers with rolled fenders...Is this a reasonable tire setup?
Don't bother staggering, as there is actually more room in the rear of these cars. Go with either size all around, with coilovers and rolled fenders you won't have a problem.
Originally posted by e30polak View PostHey I'm getting some 16x9 Brock B1s this weekend (et 15). I will be running a bigger tire b/c I'm getting turbo flares. With the flares I want to space the rims out 10 mm up front and 17 in the rear w/ 225/45/16 KDW2s. Do you think this will clear w/ the IE flares?
I also wanted to know what kind of caliper clearance would I have up front with this kind of spacing? I ask this b/c I want to know if the rx-7/corrado brakes will fit underneath?
Mystikal I'd really appreciate your input, since those 17x8s didn't workout.
Originally posted by Mystikal View PostFirst, I know someone at some point found out how space IE flares actually add. IIRC it was 1.75", but you may want to verify that first before I start crunching numbers.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Ok. So I've got my 16x9, need to pick a 215-40-16 tire now. I've narrowed the choices to the BFG G-Force sport or Yokohama S-Drive.
Can you help point me in the right direction? They seem to be pretty close on paper. I've always said I'd want performance over longevity, but lately I've been thinking otherwise.. Car is daily driver, I want a tire with a good balance of traction/treadlife. Help?
HELP
What are these wheels I have? Style 5s? What the value? The tire info is: 235-60-r16
and a pic
I am looking into getting some axis racer x wheels. staggered. 15x7 front with normal offset. The rears is where I am going to run into issues. I am going to be using fender flares, but the size and offset are kinda of extreme. They are a 15x8 with a -27 offset. Do you think I should be good with flares and stretched tires?
rear wheel pic:
I am tempted to get a set of 501's in 16x8 for winter use and put some all seasons on them. But I dont really see 225/50s on an early car having an issue fitment wise. By going with a larger tire does that make the speedo slower or faster?Last edited by nefarious7907; 09-11-2008, 10:28 PM.
