curious about spacing basketweaves
  • e30xcel
    • Aug 2004
    • 141
    I'm kinda digging the look of my painted weaves but the offset doesn't match the beautiful fender arches of the E30. I'd like to space my basketweaves out. I was wondering if anyone has this on their E30 and pics to show me how it turned out?
    right now I have 205/60 es100's on there
    hellaflush x driftunit
  • C ///M
    • 1040
    Nothing wrong with that idea.
    Atleast 15mm spacers combined with longer lug bolts, or a proper-length stud kit is easy. If you're going to do it, I'd definitely take this chance to switch to a stud kit. How stiff is your suspension? The stiffer it is, essentially the closer you can put the tires flush to the fender lips with maybe a 20mm spacer.
    332iS R.I.P.
      • 37829
      I think a 15mm spacer would be perfect. No need to worry about possible rubbage of the tires either.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • COLIZ
        • Feb 2007
        • 46
        Is it safe to use spacers that don't have a hub for the centre bore? I have 8mm spacers on the rear, and the wheels are only held in place by the bolts. Bad idea?
          • 37829
          I wouldn't use them. Go hubcentric or go home.
          Grover Beach, CA
          www.BimmerHeads.com
          • micahbertoli
            • 76
            yeah, i'm also wondering the same thing.
            was thinking about putting 15-20mm spacers on just the rear wheels, make the stance look a little more symmetrical.
            so how thick can spacers be before i have to buy longer lugs for weaves?
            • Mike325
              • Mar 2006
              • 3685
              I would get longer bolts after about 3-5MM spacer. Not sure if more or less is ok, but pretty sure that a 3mm is the max with a stock bolt. Just get some longer ones to go with the spacer MM size you go with. A 15mm spacer would need like a 50-60MM stud.
              Originally posted by Kershaw
              • AdamF 88iS
                • 2051
                I used 15mm spacers on basketweaves and it turned out perfect.
                go to parts4vw.com for the 15mm spacers, they are like $80 for a pair (way cheaper than anywhere else, I did the research for you). Search for spacers for Audi A1 chassis, they are the same centerbore and lug pattern as E30s.
                Then go to turnermotorsport.com and buy new H&R extended bolts, just look for the bolts that compensate for 15mm spacers, the description will say so. They are $2.50 a bolt at tms.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
