I would like to purchase these wheels for my 87 325is which is on Ground Control coilovers right now.
Ok so i've got to get these out of my garage.
15x7 +38 enkei RF1 (4x100/4x114.3) with 195/50/15 Kumho Escta SPT's
i got the tires back in november and have put about 7k miles on them, but they do have some camber/toe wear, and are about 50% good on one side, or 95% good if you flip them to the other wheels.
The wheels are straight and balanced, but do have some curb rash, but they're like 5 or so years old so mehh.
From my understanding, this may or not be okay for the offset. But the centerbore is definitely bigger than the E30 centerbore. When I indicated to the seller that I think I need the proper rings to match the centerbore, he says that:
So will this be a problem to not having a matching centerbore but one that's bigger? What hubcentric spacer am I going to need or do I need any at all?
well i ran my car on the track with the wheels without using rings and it was just fine.
the only time you NEED the proper bore, is for oem wheels for other vehicles, as they were designed to be used with the proper bore, aftermarket wheels are designed to be lug centric and not hub centric.
as far as lugs go, you need small ones, the gorilla small diameter lugs are very good and very cheap, you can get them for around 30$ shipped for 20 of them and a key.
