How big of a spacer would I need to fit a 16x7 +43mm wheel?
  • RyanZ06
    • Apr 2007
    • 226
    *edit* I figured out the wheel is available in +35 and +43.
    I assume I should go with the +35.. Which spacer do i need to make it look right???
    I'm looking at a set of enkei's unfortunately, it doesnt seem they make the correct offset, these are for a miata...
    • 37834
    With the 35 offset a 10mm spacer would be perfect.
    Grover Beach, California
    BimmerHeads.com
    • RyanZ06
      • Apr 2007
      • 226
      Thanks! :-D
      • RyanZ06
        • Apr 2007
        • 226
        With a 16x7 wheel with ET35 + a 10MM spacer.. I should still be able to run 225's correct?
        225/50/16 khumo MX's. Thanks!
        • RyanZ06
          • Apr 2007
          • 226
          I'm only seeing 5mm, 8mm, and 15mm spacers btw. If someone could point me in the right direction that woul dbe nice! Thanks!
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Buy the ET43 model, and run either 15mm or 20mm hubcentric spacers.
            Most 10mm spacers are not hubcentric, so since you have the option just stay away. ET43 + 15mm spacer will fit 225/45/16 without rubbing at all. Stay away from 225/50/16, your wheelwells will not like you.
            • RyanZ06
              • Apr 2007
              • 226
              I'm going to go with the +38 (i found available) and go with a non hubcentric 10mm spacer.
              Thanks!
              • Mystikal
                • 9602
                Get ready for some horrible vibrations. The car will also be resting its entire weight on the lugs, a scary setup.
                • oldskool3
                  • Mar 2005
                  • 401
                  You should listen to Mystikal he is the wheel/tire guru
                  Photoshop by O 16581 72452 5
