E30 Tire Gurus, hergekommen bitte
  • Dex.e30
    • Mar 2007
    • 153
    Mel let me jump in on the Kopi GB tonight :p Thanks Mel!
    I am contemplating the 195/50ZR15 Bridgestone Potenza RE750, Pic, to be mounted on the 6.5" rim
    Tire; 7.68" = 195mm
    Rim; 6.5" = 165mm
    So that gives me theoretically ~1.2" of rim overhang, or ~0.5" of rim overhang on each side, which I'd imagine should be I'd imagine a fairly vertical sidewall.
    Does that sound about right, or have I missed something? I don't want it to be uber-stretched, and I can't see how it would be, but want to make sure with some other eyese looking at it.
    Yes, the 16x7.5 Keskin KT1's and 225/45/16 Hankook RS2's will be FS when I get these mounted. :)
    >>> My E30 For Sale <<< ||| My MCoupe For Sale ||| Miscellaneous Items FS ||| *E30* Items FS |||
    • 37829
    Those tires are undersized. I would personally go with a 205/55 tire on that wheel.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Jean
      • 18228
      • Dex.e30
        • Mar 2007
        • 153
        I guess you guys are right. THIS is the look I am going for. Maybe just a teeny bit of stretch, and that is on a 205 on a 8”.
        I’m not planning on getting the same tires, so section width and tread width are different, but it gives me a visual representation at least.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          If you want more vertical, run 195/60/15.
          -Jay
          • Dex.e30
            • Mar 2007
            • 153
            Originally posted by Mystikal
            If you want more vertical, run 195/60/15. -Jay
            That’s a little over ½” taller than what I am currently running [3.99” vs. 4.61”], which to me already looks plenty.
            Would that give me a donut look you think?
            • Mystikal
              • 9602
              The overall diameter stays within the same size boundary. Undersized tires look crappy as well as provide less traction in every situation.
              -Jay
              • Dex.e30
                • Mar 2007
                • 153
                Ooo, good point. You are correct. 22.8 vs. 22.7 So you like the 195 or the 205 size Jay?
                Edit, I spoke too soon. 190/50 is the 22.7 for the Bridgestone Potenza RE750
                • Mystikal
                  • 9602
                  Huh?
                  Stock OD is 24.0". Your current setup is 24.0". 205/55 and 195/60 maintain within 3&#37; of those.
                  -Jay
                  • 2002maniac
                    • 4260
                    You arent going to get any stretch on a 6.5" wheel. 205/55 will be fine.
