16x8 ET38 - How big of a spacer?
  • RyanZ06
    • Apr 2007
    • 226
    I know this question has been beat to death, and I searched, but no solid answers.
    It *sounds* like I'm going to need ATLEAST a 10mm spacer up front, and probably a 5mm spacer in the back to make it "look" right.
    Is this correct?
    I'll be running 205/45/16 Hoosiers all the way around.
    Thanks!
  • backtrail69
    • Jul 2005
    • 4471
    You are going to want a 20mm hubcentric spacer front and rear with fender rolling most likely. I would spring for some studs too.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • 2002maniac
      • 4260
      a 15mm spacer would fit fine in the back and be very very close to the strut up front.
      20mm would be best. You shouldnt have to do much rolling with 205's
      • RyanZ06
        • Apr 2007
        • 226
        Also - I forgot to mention, I do have Ground Control coil overs..which should make a difference for strut clearance.
        • RyanZ06
          • Apr 2007
          • 226
          So it looks like i'm going to buy these 20mm H&R spacers from Turner... and their longer wheel studs.
          http://www.turnermotorsport.com/html...CT_ID=40234571
          Should I worry about the spacer fitting my center bore?
          • RyanZ06
            • Apr 2007
            • 226
            These look nice, has anyone used these?
            • 2002maniac
              • 4260
              not really. Unless you shortened the strut in which case you'll have less clearance.
              • 2002maniac
                • 4260
                http://www.bildon.com/catalog/Detail...=BDR420&Nav=10
                Those should do the trick. I wouldnt worry about hubcentrics. Wont matter much for auto-x or track. Get a stud kit though, it will make wheel changes much simpler.
                • RyanZ06
                  • Apr 2007
                  • 226
                  So I need to run those front and rear?
                  That effectively makes my wheels 18mm offset, so I guess that will work!
                  • backtrail69
                    • Jul 2005
                    • 4471
                    Yep. Perfect.
                    :: PNW Crew ::
                    • RyanZ06
                      • Apr 2007
                      • 226
                      Thanks guys. Ordered!
