if im running 205/40/17 7 " would i need 30 mm spacers or 25 ? and longer wheel studs if so where can i get some spacers and lugs at a reasonable price ?
Wheel spacer selection
Originally posted by crazyyardie View Postand longer wheel studs if so where can i get some spacers and lugs at a reasonable price ?
Just remember they are pretty long and not very aesthetic for a street car. ;)
911AS
15mm is the biggest spacer you would want. Stock offset varies, but usually around et25. Get either 10mm spacer, making the end offset et25 (no issues), or 15mm spacers, making the end offset et20 (possability of issues dependant on many factors including suspension and tire model).
Originally posted by crazyyardie View Postis 20 mm spacer too big ?? and will i have to roll the fenderssigpic
Originally posted by crazyyardie View Postoh ok thank u u think because the suspension is lower is why i have rubbing on the inside now ?sigpic
