Hello all, i am not new to this forum but this is my first post in the wheel/tires section. I am thinking about getting a set of wheels for my 325i. If i am not mistaken is 25 the perfect offset for our cars? Also i have seen some wheels out there that are not et 25, i do not want to run spacers so what wheels can i use with out an offset of 25 that do not require spacers. I hope this makes sense. Kind Ragards
different offsets?
Yes, these will fit with 205/50 tires just fine. 205/55 tires MAY cause a problem with a very low car at the front, meaning that the tire may touch the inside of the fender. Just MAY. Then again you won't ever have a problem with 205/50 tires even if you try to touch the ground with it.It's not an old car. It's an old friend.Comment
