15x7 et38
  • Jbpka06
    • Feb 2006
    • 551
    15x7 et38
    I am thinking 15mm spacers and 80mm studs will make these fit. Am I right?
    Will 80mm studs be to long to fit a center cap on?
  • Jbpka06
    • Feb 2006
    • 551
    I understand that 15mm spacers will fit perfectly, what about the studs, is 80mm too long or will 60mm cut it?
    • whiltebeitel
      • Apr 2007
      • 2098
      80mm is what you want, 12mm is what I have been told is the limit for the 60mm studs.
      '89 325i track sloot
      '01 530i daily
      -Enginerd
      • Jbpka06
        • Feb 2006
        • 551
        so i should still be able to fit a bbs rs center cap on with 80mm studs?
        • whiltebeitel
          • Apr 2007
          • 2098
          Centercaps are for pussies.
          I have no idea.
          '01 530i daily
          -Enginerd
          • löwenbröke
            • Aug 2007
            • 233
            unless the studs are bottoming out,(i.e. wheels will be loose.. lol) the length should have no effect on centercap clearance.
            löwenbröke crew... ya herd?
            HSTuningUSRT|Southbend|Integrated Engineering|Boostvalve|ATP|
            • Jbpka06
              • Feb 2006
              • 551
              yeah it would, you can't fit stock weave caps with 80mm studs.
