I have done tons of searching and have not concluded anything concrete (I might even be more confused lol). I have a 87 325is (high arches) and I am going with a GC setup. Whats the widest tire I can run without rubbing? I would like to avoid rolling my fenders if possible. 225/50/16's seem to be the cheapest option. Will those give me rubbing problems? Or should I stick with a 205/50/15? I would love some input from everyone. Thanks.
16x7 et20-Best tire size?
I run a 225/45 on my car with 16x8 et20. I had to roll the rears. I would run 205/50 if you want to be absolutely positive it will fit. 215/45s would be slightly undersized in your roll out, but could work also.:: PNW Crew ::
'87 325 4dr, '74 2002 -
225/50/16 is oversized and wont fit. as mentioned above, the ideal size is 225/45/16, which i ran on my 16x7 et25 with no rubbing issues, et20, not sure, may have to roll the lips in the rear just a lil bit.IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
Do some research on tire brands while you are deciding on sizes. Most companies offer a spec sheet for all of their sizes that shows overall width, tread width etc. You don't NEED 225s, most people just run wide tires to look cool I guess... The funny thing is there is such a variation between manufacturers that some 205s are as wide as some of the 225s at the tread.'88 528e /// '88 M5 /// '89 951 /// '98 E430 /// '02 M5Comment
i am running 205/50/16's with tons of room. My dad is running 215/45/16 on his 88. discounttiredirect.com has good tires w/o tax or shiping cost.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
For a M20 powered car and DD no not really do you need the xtra drag and faster wear due to camber wear?
If you use them for grip or need the extra grip then sure it's worth it the cost differance is not much, but 225-45-16's are limited size.
Toyo T1-R's
Hankook RS-212
BF Goodrich
No Michelin
Goodyear?Comment
88 (low arch) car
225/45/16 Toyos T-1Rs on 16x7s ASAs
E30 M3 Springs, Koni Yellows
Front fixed camber plates 1.25
Rear camber adjusters
No Rubbing1995 Porsche 993 6 speed
2001 BMW M3 6 speed - DD
2001 BMW 530iA Sport - Hers
2005 KTM 450EXC 6 speed
Gone:
1988 BMW M3 2.5 EVOIII Clone
1988 BMW 325is x2
1985 BMW M635CSI 286hp
2001 KTM 400MXCComment
I ran both 225's and 205's on my old Ronal LS's (15x7) and the 225's made the steering feel slow compared to the 205's, if that makes any sense. That is one of the reasons why I am leaning towards 205s at this point.
The lack of tire options with 225's bites also.Comment
On a 16x7, you'd want to run 225/45 or 205/50, with a tire wider than 205 on a 7" wide rim, the tire will give that "bunched up ribbon" look.Comment
R.I.P 07/01/09 - 04/23/10 :(
