13's on an E30
  • rodrigo
    • Aug 2007
    • 923
    13's on an E30
    Will they fit?
    A friend is willing to give me a set of BBS's off his '02 (1974 2002) for free because he's not crazy about the way they look n his car. I would use them with cushy tires for the winter...
    will they fit?
  • mattdk318i
    • Jun 2006
    • 3953
    is your car lowered? undersized wheels will be terrible for streetability. I know from experience
    * i believe they will rub the caliper.......so no
    • Teaguer
      • Sep 2004
      • 6167
      OE or BBS 13's from '02's and E21's won't clear the front calipers on E30's .
      The rear will be OK though .
      The only 13's that would really fit without too much hassle would be like the 13" reversed rims like wire wheels .
      Basically a wheel that has almost no backspacing .
      If you are after cheap winter wheels get a set of Vdub, Miata, or Honda wheels from a boneyard .
      • rodrigo
        • Aug 2007
        • 923
        I was interested in them because I like the way they look, but you guys are right....13 is way too small and the driveability would be a bit worse on an E30...aside from throwing the speedo off buy a good bit too.
        Figured I'd ask.
        I thought the same. While I was under the car during the timing belt replacement, I noticed there was very little clearance with the 14" bottlecaps as it is.
        I think the bottle caps are going to be my winter wheels...I just need to spray them a nice matching silver.
        • Spec
          • Dec 2005
          • 320
          /\ Correct me if I'm wrong, but my E30 came with 14" wheels, so it'd only knock the speedo off as much as adding 15" wheels. I run 16" currently and am going to 17".... I don't think, as far as speedo error goes, 13" would affect much.
          1991 BMW E30 318i sedan
          2005 Kawasaki 636cc ZX6-R
          PNWRiders.com
          • psloan
            • 9815
            Sell them to me.
