i got steelies
  • eyagel
    • Jan 2007
    • 756
    i got steelies
    from a honda civic with tires, what does it take to get these mounted up?
  • scBeamer803
    • Apr 2007
    • 641
    wheel bolts, lol
    • ANDRÜ
      • 1020
      You need arms to lift them into place, then bolt them up like SC said. It may help to remove the old wheels from you car, but see what happens when the time comes.
      • Mystikal
        Wheel Fitment Expert
        • 9602
        If they're hubcentric to the Civic...a friend at a machine shop. The hub bore is 1mm smaller.
        Jay
        • Axxe
          • Aug 2004
          • 3355
          I would never ever machine civic steelies out. There is at most 3 mm of material in the bore. NOT recommended unless you switch to studs, and even then you'd have to use civic style ball seat lug nuts. Oh, and the offset is high, might not clear brakes (depending on which year they came off).
          Keep it slideways!!
          • golde30
            • 11464
            uhh, the honda lug nuts i bought were conical.
            also, sidenote, Hondas use the same size/pitch threading on the wheel studs as a BMW. m12 1.5...
            IG: @Baye30
              • 37832
              Selling them is a good start... ;)
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • eyagel
                • Jan 2007
                • 756
                well i got them for free so i was just going to destroy them..or use them as my autox tires..
