225/35/17 on 7"w wheels possible?
  • mcgrath
    • May 2004
    • 445
    Looks to me that the 225/35/17's are rated for a 7.5" min rim width. Has anyone attempted this on 7"w rims? If not, does anyone know what will happen if you try to do this?
  • craz azn
    • 747
    Where did you find that tire size? Lol
    Rippin' Proper | Youtube | Vimeo |
    • E-rich
      • Jun 2006
      • 982
      theres actually quite a few tires made in that size. i just discovered them as well. i work at discount tire(americas tire in some states). so heres the problem with putting that tire on a 7. with say a 225 45 on a 7 the sidewall is gonna be buldged. causes goofy tire wear and doesnt let you you use the tire to its full potential. you will get a bout the same tire contact patch as a 215 45 17. now a 225 35 obviously isnt going to have as much sidewall to work with, causing it to not want to work very well. A) it will be a bitch for whoever is mounting it cause more risk of damaging your wheel B) whoever you have mount them may not do it because of the risk. to answer the question of is it possible, yes. would i or other tire shops recomend it...most likely not. when i mount 215 40s on 7 inch wide wheels i ask myself why......personally i wouldnt put a 225 on anything narrower than 8 inches. honestly i would recomend investing a little more money in a higher end 215 40 or 45 17 than spending the extra dough on a specialty size such as a 225 35 17. ;)
      Originally posted by rwdrift
      Back to E-Rich's car and drifters. His car is baller, purpose built. Posers are fags. KA-Ts suck. I like beer. And I need monies.
      - Erick
      • mcgrath
        • May 2004
        • 445
        Sounds good enough to me. I would put the tires on myself and I have dealt with 35 series tires on larger wheels so I know what I'm getting into (real PITA), but for the cost I will just get some 215's again. thanks for the info it was helpful.
        BTW for anyone asking why such a weired size. if you calculate that size vs the stock 195/60/r14 you will see its almost identical in size.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          Dude, look at Zimmie's car. I made him put 225/35/17 on his 17x10s, haha.
          Mounting can be difficult on a 7", don't bother. There isn't a single 225/35 made that is stickier than a 215/40/17 RT-615 anyways.
          Jay
          • craz azn
            • 747
            Jay
            Damn. Back to the RT615 idea again... grrrr....
            PS. Jay, I got one more set of wheels to go then I caught up to you :P hahahaa *coughKoseis*
            • Mystikal
              • 9602
              If the Koseis aren't either custom drilled or 17's...me no care. :p
              Jay
              • E-rich
                • Jun 2006
                • 982
                rt-615s suck in wet weather...run hankook RS2 if you expect rain in your area...
                - Erick
                • craz azn
                  • 747
                  Jay
                  Oh, you'd care if you are weighing in the difference of R comps in 15 or 17 inch in terms of dollars... Budget racing FTW! :D
                  Plus theres no cool size for any of my 3 sets of 17" rims in an R comp... they are all too small, or too big :( Maybe I should get those Rota Boosts you were referring to... hmm.... lol
                  • Mystikal
                    • 9602
                    Yeah...except no.
                    RT-615s have noticably better wet performance data than R-S2's, and gievn my experience with both I can attest that it is true. R-S2's will channel water a lot better, but as long as you're not speeding in a downpour or running the tires below the wear bars RT-615's are fine.
                    Jay
                    • Mike B.
                      • Jan 2006
                      • 987
                      I tend to agree with E-rich. My RT-615's at highway speed, in a hard steady rain (wipers able to keep up with the rain), are downright scary.
                      • E-rich
                        • Jun 2006
                        • 982
                        ^ what he said..ive never driven in rain with rt-615s but my buddy with an e30 setup similarly to mine runs them. he says its like your on ice. now i had rs2s on my car for awhile and they werent even brand new but they did pretty damn well in the rain.
                        - Erick
                        • Mystikal
                          • 9602
                          Right. Here's some test data that isn't heresay: http://www.eurotuner.com/techarticle...on_scores.html
                          Far from poor performance in the wet.
                          Jay
