A few wheel questions (Offset, Spacers, etc.)
  • SpeedTheory
    • Mar 2008
    • 27
    Will be using 16x7.5 w/225/50/16 tires for STS autocross in a 1991 318is. Just curious about a few things.
    A. What offset should I use (want to avoid spacers if possible).
    B. Will the tires clear stock fenders/struts okay? Will I need to roll?
    C. Will I NEED to use spacers?
    Thanks,
    -Ryan
    1991 318is STS Build In Progress for National Tour/ProSolo '09.
  • z31maniac
    • 17566
    If your car has the LSD, you will be in STX my friend.
    www.gutenparts.com
    • SpeedTheory
      • Mar 2008
      • 27
      No LSD, for this very reason.
      • bobross
        • Jul 2005
        • 753
        Anyway i can get the last 7 of your vin speedthory?
        -Greg
        90 325isT - 12.2 @ 120ish - Dyno Results
        b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
        • SpeedTheory
          • Mar 2008
          • 27
          Car is not in my possession currently. Back in VA and I'm in FL.
          How does that affect anything?
          • drifty340i
            • Oct 2004
            • 1076
            Offset for 16x7.5 w/225/50/16 tires would be around 20p to 28p in my opinion.
            Im using 20p with my 225/45/16s no issues
            sigpic340hp V8 e30 FINISHED!!!!!
            Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
            NEW One on the track :)
            http://www.youtube.com/watch?v=K-AX5SzSLnk
            Cleaning up some 911s and Jap turbos
            http://www.youtube.com/watch?v=Ad79wsLdle4
            • Mystikal
              Wheel Fitment Expert
              • 9602
              The tires are huge, you may not be able to get them in there. And even if you do, if you hit a bump mid-corner your fenders are screwed.
              Back down to a 215/45/16 RT-615. It's the fastest 140+ treadwear 16" tire you can easily fit on an E30.
              Jay
              • SpeedTheory
                • Mar 2008
                • 27
                If I was forced into running thin Azenis this car wouldn't even take place. It is to be a nationally competitive STS car, and running a bottom-tier Street Touring tire won't cut the mustard. Would rolling the fenders help?
                • Mystikal
                  • 9602
                  Heh, alright.
                  You're looking at rolling the fenders, modifying the plastic fender liners, and some banging in with a hammer. It will be trial and error, most guys don't try to run tires that tall and wide.
                  What are STS rules anyways? 235/40/17 will be a lot easier to fit.
                  Jay
                  • SpeedTheory
                    • Mar 2008
                    • 27
                    Limit is 225. Don't want to add the weight of a 17in wheel. My real limit is rolling fenders & adding spacers.
                    • FredK
                      • 14763
                      225 max, 140 min treadwear, Pirelli PZero Corsa not allowed.
                      What tires meet these specs and are head and heels above RT615s?
                      • SpeedTheory
                        • Mar 2008
                        • 27
                        Bridgestone RE-01R, Dunlop Direzza Z1, Yokohama Advan Neova AD07, even the Hankook Z212 is a better tire. To non class-competitive autocrossers, which I assume most of the people on here are, the difference between .5-1 second per run wouldn't matter, but this could be the difference between trophying & not, and at National Tour/ProSolo (where I think this car is really going to shine over the Civics that have dominated STS in the past), its a big deal. I may end up dropping to 15s and hoping that I end up with a better tire selection as the big players continue to release new sizes, and Kumho comes out with the new Ecsta XS, and Toyo with the R1R.
                        • Mystikal
                          • 9602
                          Yeah, that's what I was going to suggest. You can already get a 225/50/15 R-S2, and there's always the hope that the new XS and R1R will have a wide range of sizes too.
                          I still think the RT-615 is a faster than the R-S2 though. I don't know why GRM's tests (like this one: http://www.srtforums.com/forums/f136...e-test-344939/) don't match what the fastest guys are running (RE-01R and AD07).
                          Jay
                          • SpeedTheory
                            • Mar 2008
                            • 27
                            The Z1 is available in Japan in the 225/45/16, but not in the US. I've got until the '08 season to get my tire situation figured out, I can't imagine I'll be ready in it to take it to nationals this year. May find an E36 STX co-drive.
                            • FredK
                              • 14763
                              Well, I hope they do release some more tires in the smaller sizes!
