16X9's
  • Maeda
    • 210
    I too am running 16x9 et15 with 15mm spacers all around.
    YOU NEED to roll/pull/smash the crap outta fenders to get a 215/40 tire to fit.
    You can rock coilovers set at the lowest setting. I daily drive mine through socal (horrible roads) and its fine... just the driveways can be tricky, but you get good at parallel parking.
    • 808BMW
      • 2910
      Originally posted by WoodlandIX
      I'm not planning on stretching. No worries there. I was thinking a 215/35/16 or a 215/40/16. Would that work or is even rolling fenders out with that size?
      I have 225/40/16's on a 16x8, a 215 tire on a 9" rim would definately stretch. And it's nowhere near enough tire for a turbo m30.
      If you have to run 10mm spacers to clear, I say HARD rolling/arcing and 245/35 toyo t1r's. It'll be pretty undersized (a whole inch shorter than stock) which should hopefully help fender clearance. If it still rubs, you can always add more camber, hopefully you dont hit your fenderwells.
      • tubby17s
        • Nov 2007
        • 85
        225/40/16 on a 16X8 with good offset should be perfect
        • 240zs30
          • 583
          So many things to think about. I have 16x8 et 20 w/225 45 16 and I rub the inner fender under hard acceleration. Yes fenders are rolled. I can imagine when I go boost!
          • E30SPDFRK
            • 5707
            Do a 8 or 8.5 inch wheel and put 245's all around. A 9 inch wheel is too wide to fit big tires on on an e30. Ask Jay for the best offset.
            Byron
            Leichtbau
            • WoodlandIX
              • Mar 2008
              • 78
              I think im going to get fender flares for the car. If I do a 16X9" with ET15 could I run a large enough tire for traction? Is so what size? Will I need spacers for the front?
              Cars I currently own: 2003 Z4 3.0i 6 speed, 2009 328i xdrive Touring, 1979 E12 528i, 2001 Porsche 911 C2 Aero, 1992 Mercedes 300CE, 1988 Toyota 4runner
              Past cars: 1987 325is 5 speed, 1987 325i convertible 5 speed, 1994 325i convertible 5 speed, 1991 325ix sedan, 2011 135i, 1987 325e
              • Erik
                • Oct 2005
                • 5370
                Originally posted by rwdrift
                a 16x12 with a 205/50/16 tire
                That would be SICK!!!!
                -Erik
                Originally posted by 87e30
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  245/45/16 on the back = traction
                  You will need spacers on the front to clear the struts. 5mm is enough.
