I just bought a set of Borbet type e's with a 35 offset and a 64.1 centerbore. I need someone to point me in the direction of ordering a hubcentric spacer for these wheels to have them fit my car.
Point me in the right direction of help
Tags: None
Option 1: Regular 15mm H&R spacers, 64.1 -> 57.1 hubcentric ring
Option 2: Custom spacers with a larger centerbore (64mm) on the wheel side.
The second choice is obviously neater and is definitely better than using a plastic/nylon ring, but nothing is inherently wrong with the first one. If you do the first you can also reuse the spacers with other wheels. -
