318is spacers
  • longms
    • Jan 2007
    • 280
    318is spacers
    Would a '90 325 use a different spacer than a '91 318is? I bought wheels and the seller included spacers but the outside diameter of the spacer seems to be too small. Any ideas?
    '91 318is Alpine II- || HR Sport || Bilstein Sport || Poly RTAB || Treehouse FCAB || Poly Motor Mount || Poly Tranny Mount || Poly Diff mount || IE Sway Bar || BA HP Coils/Wires || 19# Injectors || SSR Comps w/10mm spacers || Hawk Pads || Fog Delete || Magnaflow Exhaust || Z4 3.0 SSK ||
  • Mystikal
    Wheel Fitment Expert
    • 9602
    Same spacer.
    • longms
      • Jan 2007
      • 280
      Should the spacer cover the entire lip of the hub or will there be a bit of a lip left over that the spacer doesnt cover?
      • ditchdigger
        • Nov 2007
        • 238
        Does the spacer cover the mounting surface of the wheel? If so then no problem.
        • EN318isPDX
          • Oct 2007
          • 4373
          Loooooose the spacers and get the right size wheels... sell those wheels to a Honda for more than you payed and pick something else up
          • longms
            • Jan 2007
            • 280
            They are 16x7 SSR comps. Please stop assuming I am trying to use honda wheels. As soon as I figure out how to post pictures then I will show you what is happening.
            • Mystikal
              • 9602
              Are they the custom 10mm ones? You'll pretty much know because they are actually 10mm spacers with a hubcentric lip on the wheel side (which Tirerack is the sole supplier of).
              • longms
                • Jan 2007
                • 280
                I am currently in NC and my pops is trying to install them in OH. I think by the looks of the picture he is trying to install them backwards. I will get this straightened out and fixed. Thanks for the help Mystikal.
                • longms
                  • Jan 2007
                  • 280
                  Upon seating the spacer against the wheel or the hub the hub-centric part does not sit flush into either the hub or wheel. There is a lop-sided gap between either.
                  I am assuming the spacer should fit right into the wheel/hub without a lot of force. Should just fit right in there.
                  (how does one post a pic without a website?????????)
                  • ejnight
                    • Apr 2007
                    • 3488
                    Photobucket.com
                    http://raceskids.com/
                    • longms
                      • Jan 2007
                      • 280
                      got it figured out. thanks for trying to help out.
