How to choose a tire?
  • mikejungle
    • Apr 2007
    • 361
    MEASUREMENTS:
    Front: 205/50 R15 86V
    Back: 195/50 R15 82 H
    Here's my tire size...can you suggest anything based on that now? And are those small? Big? Just right? Thanks
    And shouldn't the wider wheel e on the back of the car? Or is it possible for the wheels to be the same width, but have different sized tires?
    Mystikal:
    Response
    Dry Traction
    Wet Traction
    Treadwear
    Hydroplaning resistance
    Ride (doesn't need to be that comfortable)
    Noise (loud doesn't matter)
    is that even plausible? thanks
    1985 325e
    mods:
    Powerflex CABs
    MOMO Corse Exhaust
    euro bumpers with BBS front spoiler
    e36 m3 shifter
    uuc clutch stop
    • Molbius
      • 20
      tires can be sized differently on same size rim. there's a range of tire sizes that will fit. those widths are appropriate but yes, typically you would see the wider tire on the drive end of the vehicle.
      Crossfire + Pole + Isaac Newton's freakin self = sigpic
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Originally posted by mikejungle
        MEASUREMENTS:
        Mystikal:
        Response
        Dry Traction
        Wet Traction
        Treadwear
        It is plausible, but tires in that group are expensive. You basically put the most performance oriented aspects up top and followed them with treadwear...pretty tough to pull off. The only tires that successfully match what you want in my opinion are the BFGoodrich KDW2, Michelin Pilot Exalto...and that's about it; both are expensive. Everything else can do up to 3 of your top 4, but not all of them.
        Here's some good cheap choices, but you have to compromise...
        If you're willing to give up treadwear for the first three: Falken RT-615
        If you're willing to give up response for the other three: Kumho SPT, Fuzion ZRi, Falken FK-452, Falken ZE-912
        Probably a couple others too, but I generally recommend all of the above tires.
        • e34john
          • Apr 2006
          • 3599
          The BFG KDW2 looks awesome. One of my favorite tread patterns But they are pretty expensive because I don't really care about wet traction at all.
          I have the Falken 452 on my E30 and E34. They aren't the best but really good in my opinion and they are cheap plus they last forever. Not TR1s but I didn't want tires that cost more than the car.
          • Mystikal
            • 9602
            The FK452 is basically the same as the T1-R, and better in some respects. Ignore the fan boys of the Toyo, it's really not a great tire.
            • mikejungle
              • Apr 2007
              • 361
              i've already got quite a bit of negative camber...it's probably a better idea to go with a more durable tire...right?
              1985 325e
              mods:
              Powerflex CABs
              MOMO Corse Exhaust
              e36 m3 shifter
              uuc clutch stop
              • Mystikal
                • 9602
                Camber doesn't kill tires nearly as much as toe does.
                • JuanPabloBongto
                  • Mar 2008
                  • 375
                  Originally posted by Mystikal
                  First, size?
                  Then, rank these:
                  I will be needing to buy a set of four 205/55/15's.
                  my own priorities, from high to low:
                  Dry traction
                  Ride
                  Response
                  Noise
                  Wet traction
                  Hydroplaning Resistance
                  Treadwear
                  **I have a gift card for Sears, so what's your take on the best 3 of...**
                  BFG g-Force Sport
                  Dunlop Direzza (I've heard bad things)
                  Falken ZE-912
                  Goodyear Eagle GT-HR
                  Hankook RADIAL K106
                  Cont. ContiExtremeContact (pricey)
                  .... plus, what are your thoughts on Yokohama S.drive, as they would compare to the above? I have yet to hear one negative comment.
                  thanks again.
                  • Mystikal
                    • 9602
                    Dry traction
                    Ride
                    Response
                    Noise
                    Wet traction
                    Treadwear
                    BFG g-Force Sport
                    Falken ZE-912
                    Hankook RADIAL K106
                    thanks again.
                    With your priorities and that list, the G-Force Sport is definitely the choice for you. It's a great dry tire that can even take extended track driving and even lasts a long time. It's weak point is the wet, it's not as good as the best. But, it fits what you want perfectly.
                    I'm not a huge fan of the S.Drive, to be honest they let me down a bit. They're not as much of a jump over the ES100 as they should have been, given what Yokohama knows it can do (like with the AD07 Neova). In the wet they are a bit lacking, and in the dry they're not as good as the best in the class (and are actually not as responsive as the tires they replaced, which was the ES100's strongest point). Should have been more.
                    • DarkWing6
                      • Apr 2004
                      • 7144
                      I have the BFG KDW2s on my car. I have tracked the car with them and do street driving. Great tires both wet and dry. Worth the $$ IMO. I have been very impressed with them. I also know a few other people with them that really like them.
                      The tread pattern kicks ass too!
                      And Jay, seriously, do you go through tires like crazy or just read a lot?
                      • JuanPabloBongto
                        • Mar 2008
                        • 375
                        Dry traction
                        Ride
                        Response
                        Noise
                        Wet traction
                        Treadwear
                        BFG g-Force Sport
                        Falken ZE-912
                        Hankook RADIAL K106
                        ... if I promoted wet surface driving slightly, what would be my next choice? The Falkens?
                        Thanks again for your help, Jay.
                        • Mystikal
                          • 9602
                          Both. I read constantly, and so far for this year I have driven on:
                          BFG KDW2
                          Hankook R-S2
                          Falken ZE-512
                          Falken ZE-912
                          Federal 595
                          Kumho SPT
                          Toyo Proxes 4
                          Michelin Pilot Exalto A/S
                          Yokohama Parada 2
                          etc, etc...
                          I have some weird fascination with tires.
                          • Mystikal
                            • 9602
                            If you put wet traction ahead of response, maybe. The 912 is mainly a semi-soft street tire, it doesn't really feel comfortable at 10/10ths driving (I'm actually running these right now on my M3). It's a very very very very very good daily driving tire, but with dry and response up there for you, you'll want something more aggressive.
                            • idanity
                              • Jun 2006
                              • 775
                              i've heard of shoe fettish, and now tire fettish...lol
                              well, if i can add anything, it would be the side wall strength, as i like drifting and cornering.
                              then
                              i prefer softer rubber tires that wear out faster then the type that last forever and get hard, and lose all grip...(love grip)
                              also, i balance, and rotate on a 3 month rotation...(no wiggles allowed on the steering).
                              i saw a big discount on discount tires (50 bucks) and they have a lot of tires on the cheap. (like Nittos)and another 50dollar rebate w/Dunlops now
                              but im runnin falken ziexs 512s and will run the Falken Azenis RT-615's in my 225/45/17's
                              hope that helps
                              3 pedal club
                              200,k+ club
                              cabrio club
                              port-matched- polished- purring www.BMWpark.org
                              </div>
                              linux since 1999
                              • idanity
                                • Jun 2006
                                • 775
                                Nitto NT NeoGen ZR have a very good reputation (even w/heavier cars) and will be on the choice of my next set too...but i have a good trust w/falkens already...
                                i burn em up, and they do last nicely, keep their shape and i only drive it on weekends and nice days...so rain is not an issue, just grip and sidewall strenght.
                                3 pedal club
                                200,k+ club
                                cabrio club
                                </div>
                                linux since 1999
