BBS Garage: All things BBS
This is a sticky topic.
  • -negrito-
    • 91
    #766
    Question, I purchased a set of BBS RS 021 and I believe the front will poke out too much, I dont know much on proper offset.
    Specs:
    5x120
    Front:16x8 et11
    Rear: 16x9 et24
    Just want to confirm are they doable? If they do poke, I am planning to widen the fenders either way.
    Thanks in advance.
    Edit: forgot to mention Im going to use adapters
    • M-technik-3
      • 18946
      #767
      Swap the lips and keep them in the same front and rear.
      • noE30
        • Jun 2008
        • 2260
        #768
        Where are you all getting your sealant from? Online? or can I just use black rtv sealant you can find at any auto parts store?
        Flickr
        @michael.colby on Instagram
        "All he needed was a wheel in his hand and four on the road"
        • formula driver
          • 2263
          #769
          Specs:
          5x120
          Front:16x8 et11
          Rear: 16x9 et24
          Thanks in advance.
          Any fender mods? I doubt those will work with adapters.
          These have 2" lips, squared.
          Yup, that stuff works great!
          • -negrito-
            • 91
            #770
            Im planning to widen the fender.
            • noE30
              • Jun 2008
              • 2260
              #771
              Wheres the best place to find metal valve stems that will fit my rs 131s? Im using the stock lips with the "reverse lip", seems like the bolt or washer are too wide to fit inside the lip.
              Flickr
              • fporro
                • 1860
                #772
                Aloha,
                Here's a few pics of RS's 003's and 15mm H&R spacer and 11mm (5+6mm) staked spacers to clear Wilwood's 6 pot front brakes.
                What I really need is rim's that have centers with overall 13.375" diameter, measured at lip bolt's., washer and O ring represent lips
                with 11mm spacers (5+6mm) ...
                • IronmanE30
                  • Sep 2009
                  • 2121
                  #773
                  Are the brake pads fresh?
                  • fporro
                    • 1860
                    #774
                    ^ yeap, less than 16k's on them.
                    • slippery
                      • Nov 2011
                      • 379
                      #775
                      I just bought brand new stems directly from BBS in Georgia. Less than $25 for all 4.
                      J
                      • noE30
                        • Jun 2008
                        • 2260
                        #776
                        J
                        Got a link or a way to contact them?
                        Flickr
                        • noE30
                          • Jun 2008
                          • 2260
                          #777
                          Here's one of the wheels I just refinished, repainted the faces gold, polished lips/caps, and new chrome bolts.
                          Its a RS018 5x130 16x9 et36. Should be mounted on my e30 sometime next week I assume, just need to refinish one more wheel (3 are fully done) and order valve stems.
                          Rears are RS018 and fronts are RS131 16x8.5 et56.
                          IMG_0815res by m_colby, on Flickr
                          Flickr
                          • Eric
                            • 5142
                            #778
                            Originally posted by wakdog
                            Completely stripped, 1 fiberglass seat, fiberglass front and rear bar, smaller fuel tank, no heater/fan box... basically anything that doesn't serve a purpose on the track isn't there...
                            I'm at 2630 with a full tank, all metal body panels (cf sunroof though) no heater box, etc. I do have a euro S50B30, which I think is a bit of a heavy motor, and a 4 door. I'm thinking that gutting the doors might get me 100lbs???
                            2300lbs is my goal, but I don't know where I can shave another 330lbs...
                            Pad depth doesn't change with 4 piston calipers like it does with sliding single piston ones.
                            • formula driver
                              • 2263
                              #779
                              presitigewheel.com has you covered
                              Originally posted by fporro
                              Aloha,
                              [/IMG]
                              Frank, Im pretty sure you know this info, but in case you dont, 16" rs have a 12.25" face, and 17" rs have a 13" face.
                              • thebutcher37
                                • 2877
                                #780
                                Can anyone identify this waffle?
                                Its metal, but the nut is plastic.
                                EDIT NeverMind.. I found out its from a miata.
                                Transaction Feedback
