BBS Garage: All things BBS
This is a sticky topic.
    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
      Wow! Those look tasty
        Hey BBS entusiasts, I have a question. I'm reassembling my rc090's and I'm having a hard time getting the splined bolts into the holes. Do you guys have any tips? They're not easy to put in and I don't wanna risk forcing it in the wrong way and stripping the holes. Should I try some WD40 or other penetrating oil, or a lubricant, to get them to slide in? The bolts are fairly new and look brand new with no corrosion or anything. All I've seen online are people hammering them in or threading a nut on the back and forcing them though, and that seems like it could potentially damage the splines on the barrels.
        TL;DR, need to get my splined bolts in asap, help?
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
          Originally posted by Jim Lepage View Post
          Wow, those are gonna be sweet! I like how you guys are mounting the center caps too
            Vivek- rubber mallet & tap them down.
              There's the finished product of e38 style 5 with polished lips painted grimmspeed goldClick image for larger version
                I doubt you will get them pressed all the way in.
                Just give them a tap with a dead blow, as mentioned. Enough to get the splines started, and than let the nut pull them all the way through.
                  BBS STYLE 5 everlasting QUESTION
                  Originally posted by rasjgo1 View Post
                  http://forums.bimmerforums.com/forum...3#post26575553
                  Any one done this yet??
                  Or does anyone know how it done or even the waffle part # needed to attempt this
                  whats good family has anyone find out a way to make the rs waffle fit to a style five wheel yet
                      Kind of what I did but I just used a rubber mallet to get splines started then put nut on back and finished pulling splined bolt through.
                      Sent from my Galaxy Nexus using Tapatalk
                      Rebuilding since 07/06/2016
                      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                      Poorboyz Feedback Thread
                        Thats exactly what I just described. lol
                          Would anyone know if 30-hole OZ/MSW lips would work as replacement lips for BBS RS003's?
                          Thanks in advance
                          Documentation of my 1991 BMW 318iS
                            Does anybody have experience running 75 mm studs with BBS RS001 15x7 et25? Will the caps clear the studs with or without spacer ect..
                              Thanks in advance
                              Need some machining as the center of the 003 is slightly larger than the MSW. The bolt holes also need to be enlarged. Doable though.
                                Does anyone know what these are? And what their value is? Sorry I don't have a better camera than the one on my phone.
